Citizen_Insane
And you waisted $400 because you could have gone to the junk yard and gotten some teg axles that would have worked just fine for $25. You can replace a LOT of axles for $400.
Originally posted by HondaMoCo@May 13 2004, 11:52 AM
did you remove the dustshields on the hubs?
Originally posted by 92b16vx@Jun 2 2004, 12:33 PM
You can fit them, but it ain't right.
Originally posted by racingtopher+Jun 3 2004, 12:34 AM-->92b16vx@Jun 2 2004, 12:33 PM
what else is there bexides aftermarket ones?
i know you can change it to the b16 sir ones with intermed. What else is there?
Originally posted by racingtopher@Jun 2 2004, 12:09 PM
havent fixed the problem, but i read some wear that there is a spacer in the hub that needs to be removed, not sure where i read it though. havent tried this, to busy with work.
