b16a into 1993 hatchback
mmmcarl
http://hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30005 If i would like to put that engine into a 1993 civic hatchback what motor mounts do i need will the ones that come with it work. will the radiator work from the stock car/do i need new hoses. what else will i need to buy/ to do to make the swap go easy. Never done a swap before i think i might be over my head?
help would be much appriciated
Thanks
Thanks
If your hatchback is already a 5 speed all the mounts that come with the swap will bolt right in, yay!! If you are doing a auto to manual conversion all of the mounts will work except for the passenger side fram rail mount, buy this if that is what you are doing. Innovative Mounts - Product Info You can reuse the harness off your old engine because the new one is a right hand drive and wont work. You will have to add the 3 wires for the vtec and knock sensor, but that is simple. Other then that it comes with everything you need and should be fairly easy for a first timer with good mechanical abilities. Good choice going with hmotors I wont buy a swap from anyone else. I also suggest throwing the extra $300 for the LSD transmission because that is a hell of a deal!! Good luck ;)
