i have an em1 with a d16 y8 swap...i just bought a b16a2 block, what all do i need to complete this swap and what if anything from my current setup can i reuse?
All of this and an ECU for a 00 Si, B16 starter, 99-00 B16 rear mount bracket, 99-00 B16 AC bracket and compressor if you want AC, 99-00 Si PS pump and brackets, 99-00 Si dizzy. You can use all the rubber mounts from the D16. You are better off getting a complete B16 swap at this point. You need so much if you only have the long block.
