No, you can't use a cable VSS b/c it's a sir-2(electric). you need to wire it in to your cluster(search, theres plenty of threads). I'm pretty sure you use ones out of EK's.
Check your codes. it could be your VTEC Oil Pressure Switch(code 22)... but what ECU are you useing?
