b16a2
Discussion in 'Civic and del Sol - EG and EK' started by civicb16, Jun 11, 2011.
  1. civicb16
    civicb16 New Member
    is it worth buying a b16a2 for 1250$ n nothing is wrong with it just that it has no exhaust and it has 3900 miles on it
  2. E_SolSi
  3. civicb16
    civicb16 New Member
    so that answer is???
  4. rhymeshark916
    rhymeshark916 New Member
    Sacramento, CA
    Seriously? Is it legit? Two threads with the same questions. LMK. I'll buy it.
  5. civicb16
    civicb16 New Member
  6. jdmJynks
    jdmJynks New Member
    i smell something phishy... -_-
  7. civicb16
    civicb16 New Member
    it aint nothin like that
  8. Ethan
    Ethan Well-Known Member
    nothing like... a phishy vag?
  9. JDMinteg91
    JDMinteg91 New Member
    The b16a2 are streight not my fav lack low end torque but its reliable!
  10. civicb16
    civicb16 New Member
    ok but i am goin too install stage 2 crank shafts n cam gears too it so i can have better end torque
  11. E_SolSi
    you are an idiot
  12. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    :nobreed:
    1 person likes this.
  13. civicb16
    civicb16 New Member
    whats so wrong with all that
  14. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    Well first of all there not called "crankshafts" there called camshafts. And second of all all CAMSHAFTS are different and usually dont help with the low end torque which the b16's lack as JDMinteg91 said. And camgears dont do jack shit for performance. I suggest you go and do some serious research and then come back.
  15. jdmJynks
    jdmJynks New Member
    i dont like being mean to ppl and i dont like bashing on ppl, but dude have you read anything about the car, engine, drive train? you need to get you a B series builders book and several normal engine books read them and learn about how an engine works.
  16. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    Couldn't agree with you more.
  17. civicb16
    civicb16 New Member
    alright people thanks for the advice thats why i asked so many questions so i can learn
  18. STC b series
    STC b series boost or bust
    Shittsburgh, Pa
  19. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    I suggest a haynes manual. They will tell you just about everything you will need to know. But i find that searching things on google or any of the forums you learn more about certain situations.
  20. STC b series
    Shittsburgh, Pa
    ^ yes true but a haynes is not going to tell you for example that you need to pound in the frame on a crx if swapping to a b series to clear the alternator.
