B16B Rod Length?????
Discussion in 'General Tech and Maintenance' started by AllMotorB18Civic, Feb 11, 2005.
  1. AllMotorB18Civic
    AllMotorB18Civic Junior Member
    I cant find the rod length of a B16B CTR motor. Has anyone acually measured one or knows of a reliable resourse of information on it?
  2. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Um....too short to use in an All Motor B18.
  3. AllMotorB18Civic
    It is not going into my motor. I need the info for my engine design class.
  4. pissedoffsol
  5. projekteg
    projekteg Senior Member
    b16 rods are 134.36 mm (5.29 inches)
  6. pissedoffsol
    a or b?
  7. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    that sounds like A. if the B16B is a B18 block with B16 crank then it should be ~143mm.
  8. AllMotorB18Civic
    Does any one have a 100% sure of the right number for the b16b CTR rod length??????
  9. projekteg
    they're equal to eachother ;) just gave him two different units of measurement to choose from. so the answer is 'c' , all of the above. and as far as i know, b16b has regular b16 rods.
  10. projekteg
    ok, i was definitely wrong about the b16b having b16 rods. i just read somewhere that a guy who tore down his b16b, actually found p72 rods inside, if that is the case, they're 137.9mm
  11. pissedoffsol
    can't be.
    let's use some deductive reasoning here...
    deck height is the same as a gsr
    stoke is obviosuly different... less displacement.
    so, if you ask me, it would seem that a gsr rod would not work.
  12. projekteg
  13. Riceras
    Riceras Senior Member
    Dallas, Texas
    I thought they were the same length as B16A Rods
  14. nfn15037
    nfn15037 Senior Member
    Hey B, the stroke is shorter than a 1.8, right, so in order for the piston not to be way in the hole @ TDC it needs longer rods, right?
  15. pissedoffsol
    katman knows his shit... and i think he meant to type b16b RODS infact.... not pistons.
  16. formby
    formby learning in progress
    .i quote from the site
    « Re: B16b rods different length than B18C5? (allMotor93Hatch) « » 3:33 AM 10/23/2004 Reply Edit
    so you are saying that if i had a b16b blcok and put itr rods, gsr crankshaft, and itr pistons, i would have an itr motor?
    sounds like a lame ass question, but if its true, why not just do that to all of the b16b motors to make them 1.8 liters?
    what do you guys think about this?
    and this
    Stroking B16B's is a rather popular thing to do in japan.
  17. brian11to1
    brian11to1 Senior Member
    The stroke is 77.4mm... I think.
  18. GSRCRXsi
    MD
    to use more deductive reasoning. the pistons are further in the hole then itr/gsr engines. we know this because the compression ratio on the b16b is only like 10.8-11.0 right? and with ctr pistons in a itr engine you get 12+ compression. this further complicates the matter. i guess the only way to find the correct length would be to get one and measure it. maybe 97HB or 97CTR whatever his name is will see this thread. he had a b16b in his ek civic and i remmeber he took out the ctr crank and rods for gsr counterparts. he could measure them
  19. K2e2vin
    Raleigh, NC
    the compression is lower on the b16b because less stroke/displacement. if you were to stroke the gsr/itr and still use the ctr pistons and piston height it should be around the same to that of a gsr/itr with ctr piston.
  20. GSRCRXsi
    MD
    whoops i forgot about that. sorry :)
