B18a wiring on a 88' HB
Discussion in 'ECU's, Electronics, and Tuning' started by dvus1, Jul 13, 2003.
  1. dvus1
    dvus1 Senior Member
    somewhere in GUAM
    how much you think will it coz me to have a complete wiring replace on a 88" civic HB with a B18a engine in it....?
  2. hatchR
    hatchR Junior Member
    well i have an b18c1 (gsr) in a 91 hatch and the SiR ecu cost me 200, you have to get a injection resistor box and the rest is cake from there, the resistor box is about 20$ depending on where you go
  3. dvus1
    dvus1 Senior Member
    somewhere in GUAM
  4. blundar
    blundar Senior Member
    Sinsinnasty, Ohio
    if your hatch is a Si, you don't have to replace anything other than the ECU. The DPFI hatches need a Si harness, resistor box and MPFI conversion too. How much it will cost depends on how much you can do yourself.
  5. crx-1.8
    crx-1.8 Junior Member
    u can go to savage yard to get the wirering about 150 complete
  6. dvus1
    dvus1 Senior Member
    somewhere in GUAM
    thats one of the problem here, NO JUNK YARD
  7. HondaMoCo
    HondaMoCo Senior Member
    lancaster/palmdale So Cal
    YOU CANT JUST PLUG IN THE SI HARNESS- i hate it when people say that. If you have a DX hatch then you are going to need to perform an MPFI wiring conversion on your stock harness
  8. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    i ahve a complete obd 0 harness with the resitor let me know if you need it
