b18a1
Discussion in 'Civic and CRX - EF' started by murderdcrxsi, Jun 27, 2014.
  1. murderdcrxsi
    murderdcrxsi New Member
    st.louis
    So I bought a 88crx found way to much rust so I found a 91 roller I have swapped everything out with what was in the first crx...turn the key just a click I resanded grounds n bought new positive battery terminal...never owed or worked on hondas till now can anyone help?
  2. Briansol
    does the fuel pump prime (on turning the key to power-on position, not starting it)
  3. murderdcrxsi
    st.louis
    Where do I find that at?
  4. murderdcrxsi
    st.louis
    N would it be easier just to switchthe one from the first crx?
  5. Briansol
    you sit in the car, turn the key to ACC position (right before it starts) and listen with your ears to hear it prime. it should make a little noise for a few seconds. it will be behind you.(center of the rear seat area if it had one)
  6. murderdcrxsi
    st.louis
  7. murderdcrxsi
    st.louis
    No...no sounds just tgat click
  8. Briansol
    if you're hearing clicking, your turned to key too far....
  9. serrilion
    serrilion In my own little world! VIP
    Vermont
    could also be a dead batt...
