b18c1 in a 97 civic sedan lx
Discussion in 'HYBRID -> EG-EK / DC' started by 4doorcivic, Jan 27, 2004.
  1. 4doorcivic
    4doorcivic Junior Member
    what up ill be getting a 98 b18c1 engine, tranny, ecu and axles and i was wondering if i could use my factory harness for this swap anf if the integra axles will and if ill need anything else to finih it. thanks
  2. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    96-98 ex harness. youll have to lengthen the o2 sensor, vtec solenoid, and vtec pressure wires. the 'teg axles should fit.
    youll also need b-series mounts.youll for sure need the rear mount... i used my stock d-series on the driver's side on my b16, but i think the b18 might be different...im sure tim@canspeed will correct me if im wrong ;)
  3. Tim@Canspeed.com
    Tim@Canspeed.com Member
    :lol:
  4. Noeladams
    Noeladams Junior Member
    would this be about the same stuff for a 97 dx? I know the lx has the same engine
  5. civicious
    Houston, TX
    you mean the same procedure for swapping into a dx? if so, yes.
    however, if youre asking if you can use a dx harness, the answer is no.
    dx, lx, cx = d16y7 non-vtec
    ex = d16y8 vtec
    well, you CAN use a dx harness, but you'd have to rewire it for vtec.
    so:
    1. swap procedure is the same in a dx or lx
    2. no matter what, use an ex harness
  6. Noeladams
    Thanks!
    Just curious is it a lot of work to rewire the vtec? Also what if I got the complete swap without a cut wiring harness?
    sorry to be such a noob but I am done with the outside of my car now i want some real power under da hood :lol:
  7. civicious
    Houston, TX
    its a bitch to wire a dx harness for vtec. if you get an ex harness, thats one thing that you KNOW that isnt messed up, in case you run into swap problems.
    there was no usdm civic that had a dohc b-series motor. the integras had different harnesses. youre gonna have to use an ex harness (or rig up a dx harness) no matter what.
  8. Noeladams
  9. Noeladams
    Do you have any sites or links that will help in doing the ex harness or the dx one?
  10. Tim@Canspeed.com
    Actualy the D16Y7 (P2E) harness to B18C1 (P72) ECU isn't that bad.
    Heres what needs to be changed:
    VTEC Solenoid - Add to pin A8
    VTEC Oil Pressure - Add to pin C15
    Knock Sensor - Add to pin D6
    Intake Manifold Control (GSR) - Add to pin A26
    IAC (Blu/Blk wire) - Move from pin A14 to A12 (D16Y7 and D16Y8 AT use a three wire IAC. The B18C, B16A2 and D16Y8 MT use a two wire IAC.)
    These sensors require an isolated sensor ground which you can pull from pin A23.
    A pin removal tool should be used so you don't muck up the harness and break wires. Much easier to use the D series harness in this case. You do however need a few plugs from the B Series harness for the VTEC, IAC, Knock sensor etc.
  11. Noeladams
    Wow thnx man!
  12. civicious
    Houston, TX
    yeah...
    but its still teh easier to just get an ex harness, and that eliminates the chance of you accidentally miswiring something.
    its easier in the long run.
    damn you tim....
  13. Tim@Canspeed.com
    :p Not trying to disagree. Just happening alot lately.
  14. civicious
    Houston, TX
    i hope badgers gnaw off your toes. bastard.
    :D
