B18C1 Rebuild Questions
Discussion in 'Engine Building' started by swanny, Jul 20, 2005.
  1. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    My 95 GSR just rolled over to 140k and it needs some TLC. I am planning to replace the following:
    Timing belt
    Piston rings
    Water pump
    Valve seals
    Head gasket
    Clutch
    Bearings?
    Is there anything I should add to my list? Is there a rebuild "kit" available with all of the seals/ gaskets etc? Any recommended dealers for these parts? Should I have the head or block milled? Honed? Sorry for all the questions, I just need to get the ball rolling on this project.
  2. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    you might as well do a FULL rebuild then...
    since you are going as far as the headgasket and changing the bearings. Get the crank balanced and micropolished. Get new valves and valve seals as well as a slight port(if you want). Get the block honed and hot tanked. all of these aren't really a nessecisty, just ideas to get you started.
    Don't forget a new oil pump and most importantly, new head bolts or ARP studs if you like.
    AutoZone carries a FULL Rebuild kit for GSR's for about $600-$800, if I remember correctly. It comes with everything from the oil pan gasket, all the way to the valve cover gasket. Even has new pistons w/rings but i'm not sure on the rods. But I myself wouldn't trust AutoZone parts with an exstensive rebuild like this. Go OEM everything as far as the gaskets and such go. Good Luck :thumbsup:
  3. brian11to1
    brian11to1 Senior Member
    go to inlinefour.com and check out their shit.
    gaskets (TE & BE) = 272.43
    bearings are about $200, possibly..., total seal rings are about $100,
    572.43... pretty badass...
  4. civicious
    civicious FüK-VTEC VIP
    Houston, TX
  5. B16RacerN2NR
    Moving back West...
    yup, when I was working there, I sold at least 15 FULL rebuild kits for for either a B16 or LS :lol: :ph34r:
  6. sihatchback_RL
    sihatchback_RL Senior Member
    I suggest pulling out the whole motor, get a fresh hone with oversize pistons and rings, hot tank, balance crank, refresh the head, new oil pump and oil pick up, arp studs, and all those you have in mind.
  7. brian11to1
    rebuilding a motor...
    well, pulling it's a given.
    as well as a hone.
  8. reikoshea
    Dallas, TX
    lightened flywheel...thats about it...everything else has been mentioned.
