I was wondering if i could put a b20 crankshaft in my obd1 b18c1 block so that i can get more torque. If anyone has any ideas about this please hit me up cuz i think it would be tight if it actually worked.
also would it be able to make a really hybrid engine that is a b18b block with a b20 crank and a b18c1 head. im tryin to get a good amount of torque but stick with a b18 bottom end
ya but the torque on a stock ls is better than the torque on a stock gsr im just tryin to figure out how to tune it so it will run at its full potential
the ls crank creates an extra 33cc's which if you broke down your current motor which is a gsr which is a 1.797 liter, and the LS is an 1.834 liter, it wouldn't be worth the cost to do that.
You want tq, break her down and sleeve her out to 84mm's with your stock crank.
You can put a b20,b18 crank in a b18c block. This is a great combonation for racing however, may not be so great for street use. The best way to do it is to have the wrist pins moved up in the pistons to account for the extra stroke. RS machines does this all the time. And like "Calesta" said Bore and stroke and you have a hell of a motor. What you end up with is a b20 vtec with a stronger bottom end. But you use 2 motors to do it. And you end up with a bunch of left overs.
It does work, but is it worth it?
