b20b block with a b18c1 head...
Discussion in 'Integra' started by quikstr13, Oct 4, 2008.
  1. quikstr13
    quikstr13 New Member
    ok guys the gsr head is still in my car but im planning to swap blocks with a b20b i just bought today... but i wanna rebuild and beef up the b20 block before i decide to swap it... any suggestion on where to start???
  2. BrutalB83
    Rochester Hills, MI
    Build it up and beef it up for what? Boost? N/A? More details please...
  3. eurocivic91
    eurocivic91 I
    Oregon
    I'm putting a gsr head on my b20b here shortly, having the bottom end built for turbo, low comp. pistons, eagle rods, obviously new rings, thinkin about a new oil pan too lol. would Crower cams be good for the gsr head if i'm going turbo?
  4. BrutalB83
    Rochester Hills, MI
    I'll tell you what would be good...starting your own thread...
  5. 99sidude
    Ohio
    At a minimum I would beef it up with arp rod bolts and head studs. Like brutal said, we need to know your goals.
  6. quikstr13
    im planning on going n/a...
  7. teggyguy
    teggyguy high density foot.
    Colorado
    If you're going N/A you're going to want higher comp pistons bro.
    11.5:1 is what I've been told is safe on pump gas.... but our pump gas is shit any more so 11:1 is the highest i'd go for compression.
    The arp rod bolts and stud bolts are a good idea. If you really want to beef up you block re-sleeve it. At least have the cylinder walls honed. Balance and polish the crank along the way too.
    How far are you trying to go with this?
