Battery Backup for my Clifford
tab
Super Moderator
This was a lot easier than I thought it would be. :) There is a relay unit that comes with the DEI backup battery. You have a positive and negative constant, to feed the backup, with a fuse. You have a positive and negative plug going from the module to the backup battery. Last, you have a positive lead, and a (-)trigger wire leading back to your alarm. Really easy to put in, and I feel a lot more confident about my alarm system in general.
The unit was small, and easy to hide. If someone disables or disconnects my battery, the unit keeps power to the alarm, and triggers an immediate response. It was fun to test. :)
It's a large piece of mind for the $30 or so that I spent.
they work well but let me make a suggestion. check it once a month to make sure the battery is staying charged. those batteries have been know to die and you won't know until the car gets broken into.
