block guard vs. re-sleeve
Discussion in 'Engine Building' started by inspecta83, Oct 9, 2002.
  1. inspecta83
    inspecta83 Senior Member
    just needed some input for my soon to be boosted b18b1. in addition to doing cams, valves, retainers, springs, pistons and rods i was also planning on either re-sleeving or puttin in a block guard but i dont know which one would be better so i wanted to know the pro's and cons of each one. i was figuring that since it costs more to resleeve that that would be the better more reliable way to go, but i just wanted a little bit more insight. thanks.
  2. pissedoffsol
    who knows man
    theres all bad shit about everything.
    sleeves are the only real way to not blow up...
    but they are mad loot
    if you want a nuformz guard, let me know i have one... and i don't think im going to be using it anymore
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Search for a thread here... I posted a few really long items about this very subject.
    The short of it:
    Resleeve:
    - Typically $700-1000
    - Can handle whatever boost you want to throw at it
    - Is a solid installation into your block
    Block guard:
    - Typically $150 for Nuformz
    - Drops into block without needing to pull engine or incur serious downtime
    - Can rattle in between your sleeve and block, since it's not always a perfect fit
    - Can cause hot-spotting around sleeve, leading to premature failure
    - People ARE running 20-30 psi on stock blocks with just a Nuformz, and making 500 whp without any problems
    The decision is up to you.
    I would resleeve for boost, but then again- I'm willing to spend an assload of cash if I ever do decide to go turbo. I don't think it's going to happen with my current car though.
  4. paragus
    paragus Senior Member
  5. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Better safe than sorry! Spend the extra dough and resleeve it!
  6. phunky.buddha
    Yup. Thanks a lot paragus! Shows perfectly what the 'search' button can do...
