blower motor
Discussion in 'Civic and CRX - EF' started by Bobby17772, Sep 27, 2009.
  1. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    does anyone know how common it is for a blower motor to just die like with no signs. I'm going to check the fuses in the morning but one day my heater was working perfect and now it wont blow, like heat comes out but it's just because it's rising. And when I mess with the switch's some times it sounds like someone hit a microphone. Do you think that it's not getting enough volts?
    thanks
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just check the fuse and then check the blower motor its self jump it straight to a hot post and see if it comes on.
  3. Bobby17772
    Enfield, CT
    Alright, it was working fine and of course like a dumb ass I was checking the fuses and I think I pulled the one for the heater and replaced it because I was only getting signal from one side but it probably wasn't getting it in the right spot. yeah I'm gonna redo all the fuses tomorrow
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    my blower motor died in my rex...and yes they are a bitch to replace..im half way through mine :)
    but yea check all the fuses again..
  5. Bobby17772
    Enfield, CT
    wow I feel so stupid, when I was checking my fuses I must have thought that one of the spare fuse holders in the block itself was for the motor not the one far off to the side. it works now
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
  7. Bobby17772
    Enfield, CT
    yup its a true epic fail.
  8. INJEN78
    INJEN78 HS LEGEND
    OHIO
    rather have epic fail by a fuse than by having removed the whole thing..
  9. serrilion
    serrilion In my own little world! VIP
    Vermont
    Agree'd removing a heater core tomarrow cause a freinds is clogged lmao... sigh*
  10. INJEN78
    INJEN78 HS LEGEND
    OHIO
    i still need to fix mine lol..
