blue white smoke
Discussion in 'Civic and del Sol - EG and EK' started by zap45, Jul 22, 2008.
  1. zap45
    zap45 New Member
    albuquerque nm
    we finally got the right alt belt, engine sounds good can fell the car move when u rev high, anyway there is blue white smoke coming from the exhaust out of the back. Im kinda concern what up with this? when u rev high the smoke start to come not heavy. any suggestions?
  2. Aleaf.CRX
    Aleaf.CRX Hates Cunts!
    Oil?
  3. zap45
    zap45 New Member
    albuquerque nm
    i hope not i think this engine has not been started for years it has 25k to 35k miles on it
  4. Aleaf.CRX
    I think it's just burning oil, anything other than that, I don't know much more on it lol. Sorry I couldn't help more...
  5. efhondakid
    Akron-Canton, Ohio
    Blue smoke is buring oil which could be caused by any number of things.
    White smoke is burning coolant, head gasket, cracked head/block.
    Black smoke is running rich.
  6. e30etakid
    e30etakid New Member
    Run about half a can of seafoam through a vacuum line on the throttle body.
    Wait about 10+/- minutes, then go drive it like you stole it. until all the smoke is gone.
  7. efhondakid
    Akron-Canton, Ohio
    ^^Thats not going to fix a blown head gasket. If it is smoking white and blue, there is something wrong, and magic snake oil isnt going to fix it.
  8. terry
    terry New Member
    burnin oil..
    if not then those pistons dun work nomore..=)
  9. efhondakid
    Akron-Canton, Ohio
    Doesnt even make sense.:huh:
  10. delsol88
    delsol88 Blinker Fluid Specialist
    JC,MO
    hey if its only smoking in the high rpm range then its more than likely your vtec system. my buddy has that prob but i cant remember what he said. a burnt valve or something. good luck to ya tho.
  11. the.original.kermit
    the.original.kermit I know everything
    Hamilton, MI
    lol, wow, I would just ignore most of these posts. Burnt valve would cause some other issues, like running on 3 cylinders...
    Sounds like a head gasket to me. How's your coolant level, is it going down, and are you getting any bubbles in it when you take off the cap? Check the oil too, is it milky? Milky oil is a sign that water has mixed in with the oil.
    If it's really bad you can actually blow your motor by getting too much coolant mixed in with the oil. A compression and leakdown will give you more insight into the actual issue.
    efhondakid has it right, blue=oil white=coolant
  12. nplsdvr
    nplsdvr New Member
    B'ham, AL
    white smoke = new pope
    black smoke = still voting
    d'uh
  13. Aleaf.CRX
    Suddenly, I have the weird urge to go pop in Eurotrip.
  14. the.original.kermit
    Hamilton, MI
    Disregard anything before post #12
  15. zap45
    zap45 New Member
    albuquerque nm
    ok i hope its nothing serious
  16. zap45
    zap45 New Member
    albuquerque nm
    well the oil is not milky and the coolant level didnt go down. Maybe a head gasket blown
  17. the.original.kermit
    Hamilton, MI
    Burning oil is rarly a "serious" problem. Fixing burning oil is where it gets tricky.
    Burning coolant on the other had is almost always something serious
  18. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    Well if it hasent been started in a while, take it for a slow calm drive with a couple of full throttles to work off the old crap that might have built up sitting there, get an oil change and see how it is.
  19. the.original.kermit
    Hamilton, MI
    If your head gasket is blown, you would sometimes see a decrease in coolant or oil in coolant or coolant in oil, as the bad gasket will allow water and oil to travel into the other passages as well as the cylinder.
    Start up the car and check for the bubbles.
    Also, how can you tell if it's burning white if it's also burning blue?
  20. the.original.kermit
    Hamilton, MI
