b16ahybrid
The block is fully built and ready for boost.
Golden eagle Sleeves (81.5mm bore)
Wiseco coated pistons (9.5:1)
Eagle rods.
The block was professionally asseblembled using ACL bearings ... Stock b18c head bolted to the block with Golden Eagle head studs and a factory acura head gasket, torqued down per G/E spec.
Brand new water pump and timing belt.
Comes with a Skunk2 intake manifold, dist,sensors,and MSD 6-AL ignition (wired into the wiring harness for a clean install)..
Parts alone have cost me about $2,400 without labor...(block alone)
Asking $2,400 for the complete long block...
Make me an offer within reason, I DONT have to sell, but would LIKE to sell the engine....
Thanks for taking your time to look.
Oh the motor has -0- miles on it, it's been fired up, ran for a few and then shut down....
Prior to head install
http://i78.photobucket.com/albums/j103/b16...engineblock.jpg
during head install
http://i78.photobucket.com/albums/j103/b16...id/100_0401.jpg
Can provide more pics upon request...
Located in Washington state.
Eagle rods.
during head install
