Brake Upgrades
Discussion in 'Wheels / Suspension / Tires / Brakes' started by Uppertorso, Jun 14, 2003.
  1. Uppertorso
    Uppertorso Senior Member
    Winnipeg, Manitoba
    Hey guys, I have done a B16a swap into my 4th gen civic, now I am finding that the brakes are a little under par. I want to upgrade the front brakes to integra style rotors/calipers/bracket. What vehicle would I take all of these parts with??? I have tried to find this info, but to no avail. Thanks in advance!
    :blink:
  2. civiceg6
    civiceg6 Member
    I have a DA that is about to get strip. Because I'm salvaging parts from it and also got a DC2 Integra. To me it look the same and measure the same I believe so.
  3. sirex
    sirex Junior Member
    They are both the same and bolt right in. I have a 90 crx si with the b16a1 swap and I have the 'teg brake calipers , rotors, and knuckles. but I think they will only fit if you have 15 in. wheels or bigger.
  4. ciastosz
    ciastosz New Member
    Hello,
    I've got '91 CRX Si with a B16A swap made. Now I'd like to know if complete front brake system (262mm) from EK4 ('98 Civic VTI) would fit. I know it fits into EG and I heard also that EG front brakes fit into EDs. Do I need a camber correction kit?? My wheels are 15"...
  5. fastacc
    fastacc Doin work!!!
    TX
    as I understand it the eg stuff is different than ed. 90-93 teg front will work but they are about 11" so probably wouldn't work with small wheels. Also good to run the teg master cylinder
  6. ciastosz
    ciastosz New Member
    Yeah but I need info about EK4 brakes converstion into ED..I know EK and EG are almost the same, but I need to be sure...I heard that EG brakes (same as in DC2 4x100) fit into ED...and EK fit into EG...but I need short answer about putting Ek brakes into ED...sorry :)
  7. tip
    tip Senior Member
    Ennis Texas
    you can change the mas. cyl. but you don't want to use the teg. one. the one you would want to use is from a 91 ex civic sedan 15/16" and this way all the lines are in the same spot
  8. ciastosz
    ciastosz New Member
  9. phunky.buddha
    Dallas / Fort Worth, TX
    Get the 90-91 Civic EX steering knuckles, then bolt on Accord Wagon calipers if you want to go to 11" rotors. Search "4G brake upgrade" on Google and I guarantee you'll find what you're looking for. You want to look at the old hybrid-honda and crx.perf sites.
  10. ciastosz
    ciastosz New Member
