Burning enough oil to choke on
Discussion in 'General Tech and Maintenance' started by RFHOMI2U, Sep 12, 2004.
  1. RFHOMI2U
    RFHOMI2U Senior Member
    B18A, stock pistons/rings, cometic head gasket (just replaced today) and all cylinders are showing a compression test of 192psi per cylinder exactly. The second I start up the car, it runs like shit, Blows out TONS of oil smoke, and cylinders 2-3 have oil dripping off of the plugs.
    Compression tests indicate it is not rings or a headgasket, what the hell could be causing oil to fill cylinders 2-3???
    I had the valve seals changed when I rebuilt the motor, BUT----- there is oil in the intake manifold runners for cyls 2-3 ----- which could indicate possibly bad valve seals.
    It only took 10 seconds of running it for it to blow out tons of oil smoke and fill the cylinders. DEF. not rings. What could it be with a perfect compression test????
    Valve seals????? Valves???
    - oh yea, cylinders 2-3 also have oil chilling in the runners on my turbo manifold.
    thanks.....
  2. whiteLS
    whiteLS Senior Member
    Sarasota, Fl
    it sounds like valve guides or seals. i see u had new valve seals installed, could they have been installed incorrectly?
  3. RFHOMI2U
    Is 192psi a good rating for each cylinder?
    Does it definitely not sound like rings? i would hate to have to pull the engine out and rebuild it AGAIN if it only needs head work.
  4. whiteLS
    Sarasota, Fl
    i dont see how oil could leak UP past the piston rings and fill the cylenders when the motor is just setting. but on another note oil in the cylenders will give you good compression readings even if rings are bad. try a leakdwn test b4 u pull it apart agin.
  5. hybridalien
    hybridalien Member
    WhiteLs is right do a leakdown test
  6. StarBellieAngel
    StarBellieAngel Senior Member
    San Jose, CA
    to be honest... those readings seem high. from what i know it should be ~165.
    hmmm...
  7. RFHOMI2U
    Figured it out.... I feel like an idiot. Sparkplugs. Ya live and ya learn I guess.
    UPDATE: todays problem: bad headgasket, coolant leaking into cylinders.
    RESULT: Hydro lock. Time to buy a new block I guess.
  8. reckedracing
    reckedracing TTIWWOP VIP
    NY
    ??? whatcha mean spark plugs?
  9. sohcslammer
    sohcslammer Senior Member
    Bay Area
    THAT sucks. :thumbsdown:
  10. 92civicb18b1
    92civicb18b1 The Trisexual
    yea. what do you mean?
    Spark Plugs shouldn't make it smoke.
    There is 2 common ways of oil entering th combustion chamer.
    1. Seeps or in my case pours through the cylinder walls and pistons.
    2. Through the valves, seals, etc.
    My question, would coolant really result in hydro lock?
    Maybe you shouldn't mess with the new block, if you blew the head gasket, had a smoking problem and ended up with a hydrolocked engine you probably did something wrong.
  11. GSRCRXsi
    MD
    yes, coolant can cause hydrolock. it does have water in it.
  12. 92civicb18b1
    I'm not saying anyone is wrong, just learning on the way.
    A blown head gasket shouldn't cause enough coolant/water to cause hydrolock. How long were you driving it with the blown head gasket? Or if you just installed it, then are you sure it was put on correctly.
  13. BlackFrog
    BlackFrog Neighborhood Lush
    North Freakin' Idaho
    It doesnt take much water or coolant or urine or any liquid to hydro lock. Any liquid in there can do it. Liquids arent compressable, so when the piston comes up, it tries to compress something that wont compress, and things (like rods, valves, rings etc) break due to all the stress.
    Coolant can enter the cylinders if the part of the headgasket that blows is at the water jacket. Sometimes its not, like on my CRX, the headgaket is leaking oil out of #4 on the block. Not a big deal, still runs good because the compression ring is still intact.
    -Chris
