can anyone help me?
Discussion in 'HYBRID -> EG-EK / DC' started by redrocketEG, Mar 22, 2008.
  1. redrocketEG
    redrocketEG New Member
    i have a jdm 94 sir nd im doin a b18c engine conversion im not sure wat ecu i have(the car is totally standard doh) but will i need a wiring harness to fit a 98 spec engine
    thanks.
  2. BrutalB83
    Rochester Hills, MI
    Where are you? Not in the US I assume?
  3. Koop
    Koop •°o.O KOOP™
    cowtown
    unless u imported a jdm model i guess.... no shit! where are u?
  4. redrocketEG
    I'm in ireland the car is a jdm but the engine is a ukdm its a b18c6 engine i know wat 2 do for everthin else jst dis ecu shit confuses me.
  5. BrutalB83
    Rochester Hills, MI
    The wiring harness that's in the car is probably similar enough to the B18Cs wiring harness that you can just re-use it. I'd use the ECU that goes with the motor.
