i have a jdm 94 sir nd im doin a b18c engine conversion im not sure wat ecu i have(the car is totally standard doh) but will i need a wiring harness to fit a 98 spec engine
thanks.
The wiring harness that's in the car is probably similar enough to the B18Cs wiring harness that you can just re-use it. I'd use the ECU that goes with the motor.
