Catalytic convertor location?
Discussion in 'Civic and del Sol - EG and EK' started by thewraith, May 5, 2008.
  1. thewraith
    thewraith New Member
    I have a 2000 si w/a d16y7 in it. Some have told me that the catalytic should be on the exhaust manifold. My car has an aftermarket 4/2/1 header on it. There is a test pipe on there now but I have an oem cat coming in for it. Why am i being told that the catalytic should be on the manifold? I can see the cut secondary o2 sensor wires right above where the test pipe is. Can someone please clear this up for me?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    why is there a a y7 motor in a si car ?...and on the y7 the stock cat it right on the manifold off of the motor, if theres a header on the car that eliminated the cat.
  3. OKCZombie
    OKCZombie Banned
    it's equivalence of the USDM ex - he's prob in canada or somethin
  4. AHHVTEC
    Alabama
    even then it still shouldn't have a y7 in it
  5. eg6sir
    agreed.. should have a y8
  6. AHHVTEC
    Alabama
    but because the info is choppy if it does have a y8 in it the cat will go under the car the y7 is on the exhaust manifold
  7. OKCZombie
    OKCZombie Banned
    ur right wasn't thinkin 100% or readin I dunno guess that will learn me from readin and workin @ the same time.
  8. eg6sir
    how are you still around?? .. havent you ripped someone off here.. if so you get the banstick
  9. eg6sir
    yep.. sure did
  10. AHHVTEC
    Alabama
    hes i trader isnt looking good,,can i do it lol
  11. thewraith
  12. eg6sir
    it really doesnt matter.. as long as you have a cat..
  13. AHHVTEC
    Alabama
    yea thats not a si,,but that is a y7 motor so the stock cat goes on the exhaust manifold
  14. thewraith
    The driveline isn't an si. The car is an si down to the vin and carfax.
  15. AHHVTEC
    Alabama
    are you in canada
  16. eg6sir
    are you retarded?
    if you cant understand it.. let me explain.. it was an SI.. it was going to get repo'd.. the owner took the b16 out and put a y7 in thinking Honda wouldnt notice..
  17. AHHVTEC
    Alabama
    the reason i ask theres a lot mote than the b16 missing if its a real si
  18. thewraith
    Yes- like I said, the driveline (new tranny, motor, ecu, axles, shift assembly) is different and the exhaust system has been modified.
  19. thewraith
    Either way- can anyone tell me where the primary o2 sensor location would be on this car?
    thanks again
  20. AHHVTEC
    Alabama
    well theres 2 one up on the exhaust manifold and the other down under the car the primary will be up on the manifold
