Chipping Opinions
Discussion in 'ECU's, Electronics, and Tuning' started by Ractive78, Mar 11, 2003.
  1. Ractive78
    Ractive78 Senior Member
    Virginia, USA
    Im going to send me p28 ecu off to get chipped for a jdm itr. Does anbody have any suggestions on some good specs, like when should vtec kick in, rev limiter, etc...
  2. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    If you have a stock engine I suggest making sure the ecu chipper set's your redline to around 8800, because at 9k you get valve float.
    VTEC, have it set around 5300.
  3. Ractive78
    Virginia, USA
    Would I get valve float at 9k in an JDM Integra type r motor?
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i would agree w/ the 8800 rev limiter.
    as far as the VTEC point... 5300-5500 would probably be just fine.
    do you plan on running a VAFC or other type of controller at all eventually?
  5. Ractive78
    Virginia, USA
    Maybee, do you think I should get one?
  6. AllMotorMonster
    Inland Empire foo!
    Or close to it.
  7. pills_PMD
    New Albany, OH
    it will def. help and not hurt. then you can fiddle w/ the VTEC x over and find one that is suitable
  8. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    Vtec should be placed where the 2 torque curves cross. (ie first cam and second cam)
  9. pills_PMD
    New Albany, OH
    if he's buying a chipped ECU, i doubt he planned dyno time lol
  10. liquid00meth
    Laconia, NH
  11. pills_PMD
    New Albany, OH
  12. Pootie
    Pootie Junior Member
    probly a stupid question, but what do u mean by 'where the two torque curves cross'?.....isn't there only one curve on a dyno chart?....please enlighten me
  13. pills_PMD
    New Albany, OH
    set the vtec crossover to 8K and make a dyno run.
    then set it to 3K and make a dyno run
    wherever the 2 curves meet will net you the most area under the TQ curve.
  14. Ractive78
    Virginia, USA
    the stock itr ecu makes vtec kick in at 5700. Should I leave it at this, or engage sooner, like at 5400?
