Heya, i was just wondering if you had figured this out yet and what you did to fix. I seem to have the same problem here. no fuel, temp, or tach. the tach will jump a little when the ignition is turned on, telling me that its getting power, maybe? checked the plugs in the back of the cluster, tested all the wires from the plug at the distributor, to the plug at the passenger side strut tower, all tested good. no blown fuses either. i checked the blue plug from the distributor for resistance and volts, while the engine was running, and didnt get a reading. I havnt checked the temp or fuel wires yet, i figured since it moved it would be the easiest to fix. i am getting a code 4 or crank angle sensor, could this have anything to do with it? could it be a ground problem, and where would the ground be located for the cluster? and one more question where is the coolant temp sender on a b16a1 located? so far i've found 3 candidates 1 under the intake, 1 under the distributor, and 1 in the radiator. anyone have any help? thanks alot.
