Clutch pedal adjustment help
Discussion in 'General Tech and Maintenance' started by wanderinman, Jul 11, 2005.
  1. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    Ok, so I went in to check all the clearances on my clutch pedal today (96 LS) and had one major question about it. Is my clutch pedal supposed to contact the firewall? When the pedal is all the way down, it is resting against the firewall, and only about half of the piston going into the master cylinder is depressed. Should the clutch pedal be adjusted so that the entire piston will go into the cylinder? It seems that right now the clutch is not fully disengaging when I am trying to get from gear to gear.
  2. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    There is a plastic nut that you can adjust by screwing up or down on the end of your clutch cable where it connects to the tranny. If you tighten it, it will shorten your cable, thereby making your clutch disengage sooner. It is about an inch in diameter and black plastic; its the part that connects to the forky thing that holds the clutch cable in place.
  3. wanderinman
    Raleigh, NC
    hydro tranny, no cable.
  4. reckedracing
    reckedracing TTIWWOP VIP
    NY
    did you open the hydro clutch lines at all?
    if so is it properly bled?
  5. wanderinman
    Raleigh, NC
    Lines haven't been opened at all, just fairly recently stopped completely disengaging. I have a new clutch/release bearing on the way, hopefully that fixes it. But my big question was whether or not that piston should depress all the way into the master cylinder or not.
  6. reckedracing
    NY
    not too knowledgable on the piston depth inside the master
    i hope you;re getting a new pressure plate too...?
  7. phyregod
    phyregod !!YTINASNI
    Central Texas
    96 LS is a Hydro Trans... The plastic nut thing is for cable transmissions.
    Yes, the clutch pedal is supposed to hit the firewall, thats fine.
    Push the clutch pedal with your hand slowly.. You should feel what they call "free play" It should move fairly freely for about three quarters of an inch, then you should feel it firm up. I think the 97 LS is 1/2" to 3/4" Freeplay. If it is more, and it sound to me like yours is way out, you need to back off the nut on the clutch master cylinder. It is behind the pedal inside the car, way up under the dash. and its a BITCH to get to. At least for me it is, you have to bend like a contortionist and cram your hands up in there and twist the shaft with a pair of pliers at first, then you should be able to move it with your hand. Be sure to tighten the nut back up, as your clutch will be right back out of wack if you dont.
    Measure the freeplay with a ruler that is placed firmly against the floor directly behind the clutch pedal. Adjust untill it is in spec, (1/2 to 3/4 inch) measured from the bottom of the pedal.
    Here, I drew you a pretty picture :)
    Hope that helps.
  8. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Haha, awesome pictorial :)
  9. Periculum
    Periculum Senior Member
    Martinez, GA
    Is this typical of hyro trannys or is it just a honda thing? Ive got a Camaro that wont quite open up the tranny with the pedal all the way down and the piston isnt anywhere near going all the way in.
  10. xj0hnx
    C.C.TX.
    Chances are it is a similar system, I haven't really gotten into a Camaros bay, but I woud think it would be a sililar idea.
  11. Periculum
    Martinez, GA
    Well I guess ill be finding out today for anyone that needs to know.....
  12. reckedracing
    NY
    91 CRX HF
    33 MPG gas
    100 MPQ oil
    250 MPL anti-freeze
    wha??? :lol:
  13. Periculum
    Martinez, GA
    recked, thats about what my CRX was burning off until I took it apart, now its doing nothing
  14. Dman1100
    Dman1100 Senior Member
    Des Moines IA
    s13's have almost that exact same mechanism
