Cost To Build A Ls/vtec
Discussion in 'Engine Building' started by dragoon118, May 18, 2003.
Thread Status:
Not open for further replies.
  1. dragoon118
    dragoon118 Member
    California
    Hi,
    just wanted to know what the average cost for building a ls/vtec motor would be. Is 4000 about rite for a decient built ls/vtec?
    Ac :(
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    It really depends. What parts do you already have? What car is getting the engine?
  3. THiroshima83
    THiroshima83 Member
    well lets see... ls block goes for like 400... ctr pistons 300....b16 head 450... and you might want to port and polish it(900). then some ctr camshafts 500....tranny... clutch all that.. hmmm that sounds about right.. to me
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    a 900 dollar port and polish?? damn!!!
  5. dragoon118
    dragoon118 Member
    California
    i got a guy who said like 5 grand. but its fully built blue printed and balance bottom end and race pot and polised head. with type r manifold, ctr pistons, and type r tanny with lsd. he said mostly type r parts would be installed ie water and oil pump small stuff like that. is that a good deal? what else should i bee looking to get? :rolleyes:
  6. pills_PMD
    New Albany, OH
    wow.. 5000 for all OEM parts? for 5 g's expect to get aftermarket rods and pistons at least.
    balancing only costs about 200-300 if you know the right people
    too much
  7. dragoon118
    dragoon118 Member
    California
    hi,
    what should i be looking to pay for the set up i listed above?
    ac
  8. lsvtec
    Hell my balance job cost me $120, I brought him my stuff and he said he didn't have to touch anything on the pistons or rods as they were well balanced to begin with and he had to remove a little of my crank. :)
  9. JDMPowersales
    JDMPowersales Member
    Importreview.com did a great article on this. I think its about 5000 in parts and labor with out the LS motor. If you want it done right remember cheap things end up haunting you 1/2 the times.
  10. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    All prices are about average, not as hearsay.
    LS block = 400
    B16A head = 550**
    Hydro tranny = 650 *GSR/SIR
    Clutch = 300
    Linkage = 100
    Axles = 250
    Engine harness = 150 *depends on OBD1 or OBD2 costs may be higher
    ECU = 250 *stock GSR or programmed P28
    Pistons B16A = 25/ea *cannot use with aftermarket rods.
    Rings 81mm = 20/ea
    ARP rod bolts = 45 *for the LS rods if you are planing on using them.
    Pistons aftermarket = 425/set *comes with rings, can use on stock rods if machined.
    Rods = 350 *Eagles. They are the least expensive good rods, the factory LS rods will NOT handle revs over 8000 stock, and not over 9000 with ARP rod bolts. Don't cheap out here, these are the heart of your engine. Failure here can result in all your money lost.
    Rod bearings = 64
    Head gasket = 55
    Other misc gaskets for install = 100 (oil pan, camshaft, intake manifold, exhaust manifold, water pump, oil pump, etc, etc...)
    **Assuming the head came with intake manifold, dizzy, injectors, t-body, etc, etc.....
    I busted out some reciepts for machine work and labor costs from my stroked/bored GSR engine.
    Press pistons on - 60
    Bore block, torque plate - 120
    Balance crank, pistons, rods - 200
    Shotpeen rods - 80
    Port and polish head, intake manifold, exhaust manifold. All gasket matched - 950
    Clean and tank head and block - 100
    Now, I did all the assembly myself, so I saved major $$$$ over having someone else do it for me.
    So add it all up, then figure about 20% more just in case. You never know what you may run into when doing something like this.
  11. JDMPowersales
    whoa gsr tranny for 650! im a vendor and I cant even roll them up they are more like 750-1000. Most head will not come with intake manifold too. OEM B16a pistons are about 50 each. I dont quite remember. I had to buy some and it came out to 180-200.00. I could of gotten CTR alot cheaper but was in desperate need.
  12. pills_PMD
    New Albany, OH
    i got .25mm over pr3 pistons with rings for 100 bucks :)
  13. Tre
    Tre Member
    new or used and where?!
  14. liquid8
    liquid8 Junior Member
    are new pistons a must???
  15. lsvtec
    I have seen cars run fine on LS pistons, you have to be careful with your cam gears and the cams you run. It just doesn't make any sense not to replace them. You have the engine apart already you migh as well go for more compression.
  16. pills_PMD
    New Albany, OH
    brand new from "happycorepuppy" on hondavision. but i think it was an only set .. :)
  17. liquid8
    is it true that the b18 and b16 have the same bore but just different stroke. giving it more displacement
  18. E_SolSi
  19. Tre
    Tre Member
    heres a list of te costs of how much machine work ill cost me for my ls/vtec
    (PRices are in cdn)
    Shotpeen rods $60
    Resize rods for arp bolts $75 ($10 for installation and $45 for the bolts)
    Hone block $50
    Clean block, crank, rods $90
    Rod/Piston alignment/press pin in $55
    Polish Crank $50
    balance bottom end (flywheel, crank, rods, pistons) $195
    flywheel lighten $90
    flywheel resurface $50
    knife-edge crank - $180
    The guy also says new HONDA rod/main bearings would cost $300+ !!
    arp head studs $80-100
  20. Myhondasleepsforno1
    Myhondasleepsforno1 New Member
    Do it right or not at all
    B18 block
    gsr girdle
    spoon oil pump
    type r water pump (or gsr)
    Crower crank
    Eagle rods
    12:6:1 Je srp pistons
    bored 81.5 with eagle sleeves
    golden eagle ls vtec kit
    b16 head port polished milled and hot tanked
    super tech valve springs
    titanium retainers
    (can do bronze valve guides but they wear out faster)
    buddy club spec IV cams
    skunk 2 pro series cam gears
    Toda timing belt (kevlar)
    Skunk 2 intake manifold
    skunk 2 fuel rail
    310 RC injectors
    sard fuel pressure regulator
    walbro fuel pump
    blox throttle body with tps (throttle positioning system)
    password jdm intake carbon fiber
    b16 tranny
    short shifter
    act lightened flywheel
    act street racing clutch
    arp flywheel bolts
    iridium NGK spark plugs
    vision spark plug wires
    skunk 2 cam seal
    type R red valve cover
    carbon fiber spark plug cover
    p28 ecu
    skunk 2 oil cap
    password JDM magnetic oil and tranny plug
    buddy club header and test pipe
    RSR exhaust
    tein coilovers springs and shocks
    skunk 2 front and rear camber kits
    sustec front and rear strut bars
    ( i only need front and rear skunk2 lower control arms)( and I might get traction bars)
    (and if you really want to be crazy go itbs (individual throttle bodies))
    Anyway this is my ls vtec build and it was expensive to say the least but done right damn right let me know what you think.
Thread Status:
