Crome ecu good or bad for boost
Discussion in 'ECU's, Electronics, and Tuning' started by 5speed, May 8, 2010.
  1. 5speed
    5speed New Member
    Wisconsin, USA
    Obviously we all want a good engine management for tuning a vehicle. I've heard that the crome is not good for tuning boost cars for over 12psi because sometimes there seems to be glitches. But i've also heard of many people boosting more then that on crome and nothing wrong at all. What do you guys think about that?
  2. 5speed
    5speed New Member
    Wisconsin, USA
    I'm debating if i should blow off money on getting a better ecu like hondata/neptune/aem etc. Or if i should just retune at 12 psi on crome.
  3. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    crome is a hack....get hondata
  4. Matts96HB
    Matts96HB . Moderator VIP
    lmfao
    crome is not a hack
    a hack is a piggyback system (safc, vafc, etc) that does NOT alter the map inside the ecu. it just adjusts some voltages to certain sensors to trick the ecu and make it run a certain way.
    crome alters the map inside the ecu (hence the need for a chipped/socketed ecu)
    crome is an excellent program to tune with. best of all, its free.
    you buy hondata (already expensive) then you have to go PAY someone to tune it with the system you just bought. a waste IMO.
    i paid my tuner $100 over 3 tunes ago, plus $100 in dyno fees.
    basically i paid $200 to get to 320whp.
    youre going to spend a LOT more than that with hondata
    hondata DOES go into more detail. but CROME will do just fine. theres a reason why its so popular.
    edit:
    crome is NOT unstable over 12psi, whoever told you that is an idiot. ive seen the program on cars running 550ish whp with no issues.
  5. powerdriverh22
    spfld, mo
    No crome is a hack. I'm not talking about the piggy back shit. Crome is worthless, guess why its free? I've used it and hate it. Neptune and ectune are much better alternatives to hondata.
    Crome isn't nearly as popular as it used to be. everyone started seeing the obvious shortfalls and began changing to other tuning software.
  6. madracer
    madracer Boosting B16A2
    This is my experience: I have used crome and the bad things i notice is that i could never get the car to idle right with the A/C being on, and the when using bigger injectors like i have Precision 880cc with a resistor box the crome dont have the proper fuel trim adjustment, it was causing the to flood when you shut the ignition off or if the car cuts off on its own it will not start back because the bigger injectors will flood the system so it was a big pain. other than that it work fine for me with 450 injectors making 320whp with Crome, Currently I'm using Hondata S300 and is very happy with it. I don't recomend Neptune, its a pain to tune and the graph could never be clean always some glitch. Good Luck.
  7. Briansol
    crome is plenty for most cars. I've tuned a few on it and it's been more than enough.
    Would i use it on a race car? probably not.
    But for a <400 hp car, it was pllenty of features to get a safe reliable tune out of.
  8. Magana559
    Magana559 The Warden
    fresno Ca
    Crome is good tuning software only problem I have had using it was using a Converted auto to manual ECU.
  9. Matts96HB
    how is crome a hack? you still failed to answer that question.
    CROME works just fine.
  10. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    :werd:
    Crome is not a hack, it's just another program and there's two version of it(one is free). A local tuning shop, RLZ, has been making a lot of power with Crome.
  11. cant get enough
    cant get enough New Member
    ummm my advaice use the s300 hondata ecu only if u going for something right if not just use crome and i'll tell u crome have a few proplems other that it worck just fine
  12. powerdriverh22
    spfld, mo
    by hack I meant crap. Im running crome pro...hate it. I want my s200 back. Crome does work but that doesnt mean its good. Spend some money and get neptune, ectune or hondata.
  13. Matts96HB
    i have never once run into someone that doesnt like crome pro.
    sounds like a user issue to me.
    what is so bad about crome pro (specifics, not just "it sucks")?
  14. Briansol
    from a tuning perspective, i can't imagine one getting a better tune on s200 over crome.
    From a user perspective, the hondata interface is a little bit more refined, sure.. but it also costs a lot more money.
  15. 94H_Ex
    94H_Ex Under employed
    Florida
    To each his own.
  16. amadeuscr
    amadeuscr Member
    As simple as :
    hondata or crome , at the end , Honda ECU only knows one language to read. either is Hondata or Crome who is sending the information, hondata has an fancy way to do that . John Cui (crome creator) did something very smart , they gave us a peak of what crome was about creating the free version. then creating an option to advance users to datalog with the pro version. and at the end Dealer version with the Gold feature, totally rocks. I've tuned a lot of cars already with crome and hondata and standalones (AEM EMS, megasquirt, DTA ) , and they all have nice features and nice ways to work . with nice results , I believe the most important thing is who is behind the laptop.
  17. TurboRex90
    TurboRex90 Golden EG
    Maryland
    Personally i use Neptune, its pretty much Hondata but cheaper, though make sure there are tuners in your area who can do it, there are only a handful in MD.
  18. dateg513
    dateg513 New Member
    cincinnati
    i have chroe program on at least 10 cars i have built no problems at all
