ctr cams in a gsr
Discussion in 'Engine Building' started by 92Gsrhatch, Mar 14, 2004.
  1. 92Gsrhatch
    92Gsrhatch Member
    Virginia
    i have a 94 hatch with a gsr swap....how much power would i get from addin ctr cams...and do they just drop in,with no head mods....are these cams better than the TypeR cams
    .....anyone have any cams for sale
  2. 92Gsrhatch
    92Gsrhatch Member
    Virginia
  3. 97CTR
    97CTR Senior Member
    there is no set amount of power you will gain, but over the gsr cams you should notice a nice gain in power. If you do not change the stock rev limit you do not need to do any other modifications. If you want to rev higher you will need to upgrade your valvesprings. After '00 ITR and CTR cams are the same.
  4. 92Gsrhatch
    92Gsrhatch Member
    Virginia
    what springs,valves and stuff should i get
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    you can use stock. you can change to all ITR stuff for a slightly higher redline
  6. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    if i am not mistaken you just need to upgrade your intake valve springs to ITRs and move your GSR intake valve springs over to the exhaust side, now is also a good time to upgrade to tit retainers, if you desire to do so.
  7. 92Gsrhatch
    92Gsrhatch Member
    Virginia
    i really just wanna drop the cams in....the motor is fresh and i really dont have money to do anything else.....so are the cams worth puttin in with out do any other head work
  8. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    yeah i have type R valve train (all springs and retainers) that have 0 us miles on them if your interested, i also believe a friend of mine has ctr cam f/s also...lemme check and ill get back to yah
  9. 92Gsrhatch
    92Gsrhatch Member
    Virginia
    yeah very interested whats the prices?
  10. JDMilan
    Boca Raton, FL
    trust me, when you do put the CTR cams in you should upgrade the valvetrain compenents to waht I mention and also get a ITR base map on you ecu.
    that is what I would do, and recommend.
  11. 92Gsrhatch
    92Gsrhatch Member
    Virginia
    ight well does anyone got any of this stuff for sale
  12. B16
    B16 Super Moderator VIP
    yay area, CA
    i'm running CTR cams on stock valvetrain and ecu in my del sol, works great. you only really need to upgrade your valvetrain if you plan on revving past stock rev limit, otherwise it is not all that necessary.
  13. 92Gsrhatch
    92Gsrhatch Member
    Virginia
    i dont wanna rev pass stock rev limit
  14. JDMilan
    Boca Raton, FL
    ^^ thats fine, but from my standpoint......I would use the full ability of the cams given - as in terms of making power past 8k.......
    either way youll be fine,,,but if you plan on going past 8k upgrade the valvetrain components along with a ecu tune....good luck man.
  15. B16
    yay area, CA
    very true, the cams do want to pull past my limiter, on the track i do hit it often. but, it is also a great cheap power adder, just putting the cams in themselves.
  16. AlphaCivic
    AlphaCivic Member
    San Diego
    CTR cams would be a great way to go on a gsr. You will definately feel a differance, and without compromising drivability. *grin*
    very highly reccomend you do springs and retainers to take advantage of the high rev pull those cams will make.
  17. 92Gsrhatch
    92Gsrhatch Member
    Virginia
    so what valve springs and retainers should i get for this set-up
  18. lude68
    lude68 Senior Member
    type r should be fine unless you plan on upgrading anymore and the future....
  19. 92Gsrhatch
    92Gsrhatch Member
    Virginia
    if i upgrade my valvetrain where is it gonna be safe to shift at
  20. 92Gsrhatch
    92Gsrhatch Member
    Virginia
    how many rpms can i gain by switchin the valvetrain
