D15b1 code trouble
Discussion in 'ECU's, Electronics, and Tuning' started by blackice90HB, Jul 25, 2005.
  1. blackice90HB
    blackice90HB Senior Member
    Pensacola, Florida
    my 1990 civic hb std throws a cel when i try and start it. the flashes from the ecu is one flash, pauses for a sec. then 16 consecutive flashes. this means that its flashing an error code 1 and an error code 16?
  2. vtecjdm
    vtecjdm Senior Member
    I think the code is 16. The ecu always flashes once when it`s jumped.
    Then gives u codes.
    Correct me if i`m wrong guys
  3. blackice90HB
    Pensacola, Florida
    i dont have to jump it, its obd0, it flashes when the key is turned to the 'on' position.
    edit: thanks for the feed back
