D15b2 with d16z6 head?
Discussion in 'Engine Building' started by erikespo, Apr 21, 2005.
  1. erikespo
    erikespo Senior Member
    Western New York
    Will this swap work> I have a complete d16z6 engine and I want to know if i can swap the head onto my d15b2. I am going to get my engine compression check to see if i have blown piston rings or if it is the valve seals on the exhaust side.
  2. old Skuul Hatch
    old Skuul Hatch Senior Member
    Honesdale Pennsylvania / Fort Smith Arkansas
    should
  3. erikespo
    Western New York
    I did a little bit of math and the CR looks like it should be around 10.2:1
    .. just to be clear I am going to use everything off the d15b and just swap it on to the z6 head?
  4. ricerking13
    ricerking13 Junior Member
    Just so you know you'll get a very substantial gain by swapping the IM for the z6 in, and are you currently DPFI or MPFI? Because that might require a swap, I recommend www.D-series.org for a lot more info on this swap...
  5. erikespo
    Western New York
    really you gain power? I didn't know that.. I just wanted to do it just because..
    No crap you gain power.. That is the whole point of doing it. Thank you mr obvious
