Will this swap work> I have a complete d16z6 engine and I want to know if i can swap the head onto my d15b2. I am going to get my engine compression check to see if i have blown piston rings or if it is the valve seals on the exhaust side.
I did a little bit of math and the CR looks like it should be around 10.2:1
.. just to be clear I am going to use everything off the d15b and just swap it on to the z6 head?
Originally posted by erikespo@Apr 22 2005, 06:33 AM I did a little bit of math and the CR looks like it should be around 10.2:1
Just so you know you'll get a very substantial gain by swapping the IM for the z6 in, and are you currently DPFI or MPFI? Because that might require a swap, I recommend www.D-series.org for a lot more info on this swap...
