D15B7 vs. D16Z6 Head Bolts
Discussion in 'HYBRID -> EG-EK / DC' started by Bigmojoj27, Apr 14, 2004.
  1. Bigmojoj27
    Bigmojoj27 Junior Member
    Ok, I'm doing this head swap, and it's coming time to buy new head bolts. First of all, are the B7 and Z6 head bolts the same? Second, I want to get ARP head studs, but they only sell them for "D16Z" on inlinefour.com. The swap requires D15B7 head bolts, but could I use the head studs from the Z6?
  2. E_SolSi
    when i did my mini-me i used D16Z6 head bolts with no problem
    i would immagine you could use the D16Z6 ARP studs with no problem
  3. Bigmojoj27
    Ok, just as a note, I'm doing the mini-me with the Y8 head on the B7 block... I don't know if that make any diff, but people said i should be using the B7 bolts, not the Z6 bolts. Does it make a difference now?
