d16y8 to a gsr
Discussion in 'Civic and del Sol - EG and EK' started by 94civic_si, Oct 23, 2008.
  1. 94civic_si
    94civic_si New Member
    texas
    ok i have a hook up from a friend. he has gsr that he dont use.
    so i want to know if it would be a hassle to swap it in my d16y8 1994 civic si (eg).
  2. delsol88
    delsol88 Blinker Fluid Specialist
    JC,MO
    search search search. you need to go to www.hmotorsonline.com and look for a complete swap. depending upon what you get u might need axles. motor and tranny mounts, shift linkage, and ecu if not of that comes with it.
  3. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    He doesn't neeed to go on hmotors or anything, his friend already has the motor.
    Pretty much just look up "B-series" swap. It's a very easy swap and bolts in using the correct components(pretty much just Integra stuff).
    Also, was the motor swapped? 92-95 Si's came with D16Z6s, And, technically, it's an EH and not an EG ;)
  4. delsol88
    JC,MO
    ur right bout that. but i was only using hmotors as a reference list as to what he needs if he looked at a list of the complete swap.
  5. 94civic_si
    texas
    lol eh ok.. and yes its a swap i bought it like that so idk much about it. so im guessing i have obd2? and my tranny wont work with the gsr huh?
  6. delsol88
    JC,MO
    well what year is the motor? 96+ gsr motors are obd2. so you tell us what you have and we will tell you what you need. like as far as parts wise and stuff.
