d16z6 into 89 rex hf
Discussion in 'Civic and CRX - EF' started by turbo sol, Oct 18, 2006.
  1. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    i'm gonna be swapping a d16z6 into my manual crx and want to know what all it takes to get it done. my car is already multi point injection. need help.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just drop it in and wire up the vtec
  3. ef8
    ef8 Junior Member
    Wrong.Your going to have to convert to obd1 also in order to actually have VTEC.Just go to Rywire - Online Store and grab up some harnesses.Your also going to need a 4 wire o2 sensor,the obd1 ecu(p28) and a cable tranny.The Z6 tranny is hydro so if it comes with the tranny just sell it and buy a crx si tranny because that HF tranny sucks bad.You arent going to be going anywhere fast with that thing.Your also going to have to swap out the driver side mount with the one from your HF motor.SO convert to OBD1 and Get a Si tranny.
  4. AHHVTEC
    Alabama
    this is true i just didnt mention the detals because after already typing the same thing in 2 other post i just figured he would see it, but depending on ecu you use wether you use a 4 wire 02 sensor for exsample if you use a po8 you need a one wire but just go with the p28
  5. ef8
    ef8 Junior Member
    seem to get ALOT of these same questions on here
  6. AHHVTEC
    Alabama
    yup i think it might be a lack of using the search feature :D
  7. turbo sol
    sorry guys. was being lazy. but that sounds pretty simple. can i just change the final drive gear to lower the gear ratio to compensate for the high gears?
  8. BlueCrxNC
    BlueCrxNC VTEC CRX
    You can put a higher final drive on the old HF transmission if you want. You'll go through the gears faster for sure. But since you'll already have it torn down, you'd might as well fix the rest up as well; bearings etc.
  9. BlueCrxNC
    BlueCrxNC VTEC CRX
    If you do that, you should trust the seller before you just throw it in. If you don't trust them you'll want to check it's internals for condition or pay someone else to do so.
  10. dok
    dok Senior Member
    guys doesen't the hf have different axles then the si doesn't he have to change his sipndals as well
  11. BlueCrxNC
    BlueCrxNC VTEC CRX
    ONLY the outboard (hub end) joints are different. In other words, no.
  12. nickscivicsi69
    nickscivicsi69 Drive it like u stole it
    Tampa
    ok but hows he gona know if hes getting an si trany they all say L3 dont they??? and u can do other things besides the whole p28 ecu and harnest kit if u wanted to..Ef-honda.com look at the engines swap section some tid bits of info that might help you out but like someone said already reserch ur swap and get all the info u can get before you get all into it..
  13. BlueCrxNC
    BlueCrxNC VTEC CRX
    I really hate half-assed stuff people do like this. Then they ask why it blew up... LOL
