sunnysideup
i just did a 1995 d16z6 swap into my 1992 eg that had a d15b7 in it, the swap went smoothly but we are having a few problems, the car will idle but does not want to start or run sometimes, and when it does run it will on rev up a bit and then the rpms surge similar to launch control or limp mode, i am running a p28 ecu and and si transmission i am also throwing codes for my o2 sensor, my iacv,my map sensor my tps and my a/c current, but i know for a fact that the map and tps sensors are good because they have been replaced any help would be really appriciated because i need my car...=[
