d16z6 No Spark
n8hoover
I have a d16z6 with a y8 head in my 1990 Civic DX. I had a no fuel problem, but the obd1 conversion helped fix that. After that i have no spark. I took the dizzy out and put it in a friends car and we had spark. I have ran out of ideas on what it would be. any help would be appreciated. Thanks
Well, my crystal ball says we need a ton more information so let's get started.
Much more information about the car, and the swap. What ECU? What wiring changes were made? Adaptors used, etc. Who did the swap? Who did the wiring?
It should be throwing CEL codes - is it? Probably CYL/CYP errors.
Pictures are always welcome. Send pictures of the engine harness at the distributor and such. You have a ton of basic things to check. First, are you sure it has fuel pressure?
What ECU is in it now? If you don't have wiring schematics for your car and something the engine came out of in OBD1 configuration - get them. Google is your friend - the schematics can all be found online.
Welcome to the forums sir.
