distributor wire location pic
Discussion in 'Civic and CRX - EF' started by goose2, Mar 4, 2008.
  1. goose2
    goose2 New Member
    dx to sohc non v-tech zc swap are the wires in this diagram correct?
  2. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    What is a non-vtech? ;x
  3. goose2
    goose2 New Member
    like a 1.6 crx si motor
  4. jlicrx
    jlicrx Senior Member
    Colorado Springs
  5. goose2
    goose2 New Member
    that helps thanks.thats just how mine is.my ecu is blinking 8 times tdc.and everywhere i have read says that its more than likely a wireing problem.i followed the instructions from zcspeed to the T (dx std to zc swap).i have ran down every wire.
  6. dannyboycivic
    dannyboycivic New Member
    Oregon
    when i did my wiring i had the same problem. the ecu was giving code 8. the dizzy plug was right but the harness at the ecu was wrong. I plugged the wires in 8 and 10. the needed to be in 10 and 12. stopped throwing code and runs like a champ.
