Dyno'd the 'rex today!
Discussion in 'Civic and CRX - EF' started by civicious, Dec 1, 2006.
  1. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    I'll have to wait until I get back to my apartment to upload the dyno sheet, but it put down 160hp and 140tq on a 75 shot... w00t!
    D15B, K&N filter, DC header, test pipe, Thermal R&D exhaust, Fidanza flywheel, Exedy clutch, and a Zex dry 75 shot...
    my AFR was right at 14.7-14.9...lol
    w00t!
    only one pic for now...I'll put up the dyno sheet later tonite, and a guy from my class is supposed to email me more pics that he took with his digi...
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    what did it do with out the shot
  3. civicious
    Houston, TX
    N/A it made 108hp 85tq...lol
  4. AHHVTEC
    Alabama
    wonder what it would take to get those numbers without spray or turbo on the samr motor
  5. civicious
    Houston, TX
    lol...it'd probably take a miracle...or individual carbourators :p
    here's the dyno sheet:
    67.66 degrees F, 30.17in-Hg, 7% humidity...
    Max Power = 161.76, Max Torque = 140.37
    and love those nice, smooth curves after VTEC at 5500rpm!
    :D
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Whoa, pretty lean. You going to get your stock ECU to compensate or just change the fuel jetting?
  7. civicious
    Houston, TX
    I'm gonna blow that motherfucker up...lol
    :D
  8. TurboMirage
    i would bet my mirage makes more power than your z6 swapped CRX :)
  9. civicious
    Houston, TX
    too bad I don't have a z6 swapped CRX :)
  10. eg6sir
    :werd:
  11. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
  12. AHHVTEC
    Alabama
    lol yea but it will still be slower
  13. B16RacerN2NR
    Moving back West...
    cool...
    y0 Wil, don't worry...the next motor will put down more whp completely stock :thumbsup:
  14. K2e2vin
    Raleigh, NC
    gayyy.
    I might take my car to TX(my aunt lives in Fort Worth) one day, and show you what a D15B can do ;)
    Second thought, thats a fuckin 18hour-ish drive
  15. danse
    danse Junior Member
    I'm looking at your dyno run, when did you hit the button? Your HP and Torque are all over the place...
  16. reikoshea
    Dallas, TX
    werd. i woulda thought you woulda had more sense than to run a dry shot.
  17. civicious
    Houston, TX
    I didn't hit a 'button' per se...it's set up on a voltage-engaged WOT switch. We started sampling the second I floored it at around 4100rpm, so the entire graph is on the spray.
  18. phunky.buddha
    Dallas / Fort Worth, TX
    I think you might make a bit more power if you add some more fuel... looks good though! Where did you get it done- at school?
  19. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    7% RH, wow you guys got some dry air. What did the nitrous cost you? From what it sounds its cheaper than a turbo?
  20. TurboMirage
    d15b whatever :lol:
