ECU Problem
Discussion in 'HYBRID -> ED-EF / DA' started by MaddogPA, Jun 29, 2016.
  1. MaddogPA
    MaddogPA New Member
    I swapped a B18 and a CRV manual tranny into my 89 ,Automatic all wheel drive wagon. I have code 4 and code 6. I have tried 3 different PR4 ecu's and 3 different distributors. Same result.
    However when I install a PM8 HF Ecu I only get code 14 electronic air control? Anyone know what to do next?
  2. Briansol
    I'm guessing you have a wiring problem at this point. Re-check your wires.
    what harness did you use?
  3. Solomon93
    Solomon93 Member
    Sounds Like an improper MPFI conversion wiring and a disconnected sensor or broken connection between the sensor and ecu like mentioned above.
