Elecrical Load Detector! Help
Discussion in 'ECU's, Electronics, and Tuning' started by elwood79, Jan 21, 2008.
  1. elwood79
    elwood79 New Member
    I plugged a code reader into my 97 honda accord to see if there was anything wrong with it and it told me this..."electrical load detector circuit high input"
    does anybody know what this means and if it is very hard to fix?
    Please help, I have no clue what to do
  2. Briansol
    ELD is in the distributor. check your timing, spark plugs, and perhaps use a better octane gas.
  3. reikoshea
    Dallas, TX
    It also goes off due to a missed ground...as the time spent under the hood of the lude has taught me.
    Check the big 3 grounds. (Valve Cover, Thermostat and Transmission)
  4. elwood79
    elwood79 New Member
    Thanks a lot for all your help, reikoshea and B, i had no clue as to what that meant.
  5. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    no!!! old~ish thread. the ELD is in the under-hood fusebox!!!
    not in the distributor!!
  6. reikoshea
    Dallas, TX
    depends on the car.
    kthx.
  7. elwood79
    elwood79 New Member
    So what do i need to check for in the under hood fusebox? A bad fuse or something?
    I have already changed spark plugs and wires.
  8. reikoshea
    Dallas, TX
    thats where the eld is/might be.
  9. YBLEGAL
    NW Indiana
    well yeah as reikoshea says, might be. i'd say 99% chance it is. honda likes to keep it simple.
    the bad news is, the ELD isnt a servicable part. it's integrated into the fuse box innards. you'll have to probably get a new under-hood fuse box. i dont know anyone first hand that's had it go bad. but ya...
  10. reikoshea
    Dallas, TX
    well it doesnt go out often, usually its an alert of something else, like the distributor or a short in the wiring.
  11. YBLEGAL
    NW Indiana
    high input would lead me to belive a sensor is malfunctioning, outputting a value much higher than the ECU expected, or that the circuit expected. mmmaybe if you had a higher amperage fuse than what something is supposed to use. just some guesses.
