f/s..bbk throttle body,obd1 injectors,90/91 crx gauge cluster.ect
goldgreen90ef
goldgeen90ef
jdm d15 vtec intake manifold $30 plus shipping
jdm d15 vtec throttle body no sensors $ 15 plus shipping
obd1 injectors $ 20 plus shipping
obd 1 injector plugs x3 $ 15 plus shipping
bbk powerplus 62 mm throttle boby for b-series has map sensor, bolt a littlestripped, can be fixed , $300 new from summit $50 pus shipping ( i paid $100 for it used)SOLD
venon 400 module obd1w/ harness no instructions, ( found instructions on internet)$50 plus shippingSOLD
90/91 civic si gauge cluster w white face that glows orange w/ lights on $50 plus shipping
b-series hydro slave cyl. only installed on car for month$10plus shipping
da defrost switch $ 10 plus shipping
b series =iacv $10 plus shipping
f22 iacv??? $5 plus shipping
obd1 fuelrail $15 plus shipping
88-91 crx clutch cable $25 plus shipping
d16z6 distributor never used, need plugs, $40 plus shippingSOLD
t3 oil line, line good, need new fitting $10 plus shipping
stock gsr shifter $10 plus shipping
stock da airbox w/ tube and filter $10 plus shipping
PICK UP ONLY....
B16 header, large bottom tubes, not sure off of what model $20
motegi 16 inch rims, one has rust from being stored in barn, 2 ok tires, to bald, $125
all item are o.b.o., located in cuyahoga falls ohio 44221, will take post office money order, check, or paypal f you walk me thru it.....
thanks robbie
Just A Little..its Still Totally Usable, Iwas Gong To Drill A Hole In It And Use A Small Cotter Key, Or If You Can Weld You Can Spot It On...but That Doesnt Even Realyy Matter Because Its Flat On Both Sides So Its Locked Onto Anyway..heres A Pic..
will you take $75 for the wheels? shipping to indiana 46818 pm me let me know!!!! -Ryan
shipping would be cheap seeing as how were only 200 miles away, and ill throw you 100 for the wheels, plus shipping! Take it or leave it. -Ryan
