failed smog FTL!
Discussion in 'Members' Lounge' started by eg6sir, Nov 1, 2011.
  1. eg6sir
    went to smog the pickup today.. bam, failed.. wtf?!? passed w/ flying colors 2 yrs ago w/ very low numbers... still had very low numbers except one test
    15mph HC: max 133, meas 12... CO: max .59, meas .01... NO: max 1050, meas 1224
    25mph HC: max 113, meas 13... CO: max .74, meas .01...NO: max 910, meas 80
    whats causing me to read so high on the 15mph and read so low at 25mph on the NO test?
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    What is this "smog test"? Is that something over in thar yonder commiefornia?
  3. eg6sir
  4. reckedracing
    reckedracing TTIWWOP VIP
    NY
    wrong gear used for the test would be my only guess
    kept the truck in 1st and spun it to 15mph revving the motor too high
  5. eg6sir
    i saw him shift it for the 15 mph test
  6. reckedracing
    NY
    so the test requires a specific gear?
    perhaps the motor was spinning too slowly and loading up resulting in excess gas in the exhaust
    seems it would have a direct relation to engine rpm to have such a huge difference between the 2 speed tests
  7. reckedracing
    NY
  8. eg6sir
    yep.. i have a thread going there too.. lol
  9. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
    If I'm not mistaken, isn't nitrogen oxide what the catalytic converter converts? I know the platinum catalyst in the presence of an alkene leads to hydrogenation of that alkene, but I'm unsure of the effects on inorganic species... Just a thought.
  10. B16
    B16 Super Moderator VIP
    yay area, CA
  11. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Is the cat one of those 2 year cats that were going around? What I mean is.....did you buy a new cat for the last smog and now its not cutting the mustard?
  12. E_SolSi
  13. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    What was your o2 @ on the 15mph run? NOx is usually the indicator of running lean. So if your o2 is kinda high, look into things that would cause "too much air" to be entering the engine. If your o2 is still somewhat normal, look into things that would cause "not enough fuel" to be entering the engine.
    I'm sure you know what lean and rich are lol, but you'll be surprised at how many people don't realize that not enough fuel could be lean and not enough air could be rich as opposed to people seeing rich and going straight for fuel and seeing lean and going straight for air...
  14. eg6sir
    it measured 3.06 @ 15mph
    i'll be sending in an application for CAP, CAs repair assistance program.. $500 towards repairs
  15. UNDR8D
    UNDR8D ...has a job!
    8OH!5
