LS_VTEC
you get the BRAKE
B18a1 short block, deglazed and honed, chemical bathed.
shotpeened ls rods
arp rod bolts (8mm)
acl rod bearings
pct pistons (ctr -- 81mm)
total seal piston rings
acl main bearings
polished crankshaft
ctr crankshaft pulley
new oem honda keyway
new oem honda timing belt tensioner
oem gsr water pump
oem itr oil pump
gsr timing belt
new rear main seal
Engine is assembled with all brand new parts. This short block has 0 miles. Need to sell to finish a boost project. All clearances are within oem honda specifications. The only thing this short block is missing is an oil pan. Has windage tray and oil pickup as well. $1000 firm. Will ship but prefer pickup. I will post pictures of the finished product tonight or tomorrow.
shotpeened ls rods
arp rod bolts (8mm)
acl rod bearings
acl main bearings
polished crankshaft
oem gsr water pump
oem itr oil pump
gsr timing belt
new rear main seal
