Check the fender line on an existing EK, then match it up to the door on your EG. Hell, get a giant piece of butcher paper and trace it out on the EK, then lay it on your EG. Easy. Then you'll know if you have to cut and weld.
When cutting and welding is required though, you're usually splicing the back end of your original fender with the front end of the new fender. That way you're guaranteed to match the original door line of your car.
