NY FS: Sleeved/built D-series with turbo setup and transmission
Discussion in 'Parts: For Sale/Trade/Wanted' started by mafdark, Aug 5, 2010.
  1. mafdark
    mafdark New Member
    Head has already been sold
    Engine:
    mileage since rebuild: approx 3k
    Benson Sleeved Y8 block
    .20 over CP pistons
    Eagle rods
    ARP rod bolts
    cometic gasket
    ARP headstuds
    ACL bearings
    new oil and water pumps
    tapped oil pan
    Spec stage 3 sprung 6 puck clutch/pressure plate
    Stock flywheel
    Turbo:
    Sard Blow off valve
    New AFI custom ramhorn
    New AFI 3" downpipe
    Godspeed intercooler
    braided steel hoses for oil cooler, turbo oil, turbo coolant
    Trans (Z6)
    New bearings
    New syncros/hubs for 2nd/3rd
    OBX Limited slip
    Misc:
    P28 ECU w/ECtune
    If someone wants this setup I can also help locate a GT28RS turbo, I've sold it to make way for the new setup which I'm still working on.
    Dug up some more pictures from the build and such:
    Ballpark prices:
    trans: $500
    Block/clutch+flywheel: $2,000
    Or: 1,750/200
    Manifold/downpipe/BOV/IC: $750
    Or: 400/150/60/200
  2. mafdark
    mafdark New Member
    bump
  3. skimboard71104
    skimboard71104 New Member
    jersey
  4. mafdark
    mafdark New Member
    everything sold. thanks though.
