Fuel Guage Doesn't Go Down Much
Discussion in 'ECU's, Electronics, and Tuning' started by 05X, Jul 17, 2008.
  1. 05X
    05X New Member
    I have a Civic SI Guage Cluster and I noticed that the fuel guage needle doesn't seem to be dropping much every time I drive. I have driven over 140 miles and the needle is still more than 3/4 and a little less than full. It's weird. Normally, I would be close to half tank by 140 miles. Also, I tried moving the needle manually, but it went back to where it was. It just started happening. I doubt I'm getting 40 mpg-more like 29 mpg. I have an LS engine by the way. Any ideas?
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    the float in your fuel tank might be sticking
  3. 05X
    05X New Member
    What's a "Float" and how do I fix it? :mellow:
  4. 95EGCoupeVtec
    95EGCoupeVtec SOHC VTEC at its best
    South Mississippi
    the float in your fuel tank is what floats on top of the surface of the fuel in your tank and sends a signal to your gauge cluster to move the needle up or down. if the shaft that it moves up and down on is dirty/dry , then it will stick. it is located in the tank right by the fuel pump.
  5. craiger
    craiger New Member
    Austin, Texas
    It could also be the electronic looking thingy (sorry dont know the specific name) attached to the fuel pump. If you take out the entire fuel pump assemble you will see the float at the end, the arm that goes to the electronic thingy I am talking about. I have had this happen to me before. You might have to replace the entire fuel pump to fix this problem. Good Luck.
