its a 95 gsr into a 97 civic si .. i can hear my pump priming i got fuel in the canister i donno if i have fuel going into the fuel rail but i got so much pressure wherre the fuel rail connects its starting to seep out. \
Dizzy - i had to switch the plug on the dizzy and i took it out and didnt think to mark it didnt think that would have so much play or etc. i took it out put it back in brought the number one piston to the tdc and the way the camshaft is placed the dizzy will only point to 4 and 2 well in between 4 and 1.
ckf -(is what i mean) i donno if i havfe it right but i spliced the 4 wires. it says to join the c1 and c4 but keep the yellow wiring goignj into the ecu which is c4. also c11 and c14 brought them together kept the c14 runninh thru which tricks the ecu to think it only has one crank flunctuation sensor.
injectors i have no clue if theyre evedn injecting becuz the pistions are so dry u dont even see them shine inside the block when u take off the sparkplugs.
i also wired up the iab brought it thru the fire wall and attached it to a17 for the gsr obd1 i didnt know how to pin it in the clip so i left it hooked up directly to the computer . the jumper harness runs from the obd2a it runs the iab on a26 and runs to the obd1 to a17 for the iab i checked all pin outs. So i figured i could jus hook it up there and i didnt kno where to hook up the black wire for a ignition switched +12 volts so i tried the power for my deck. maybe that could be the issue.
since i am gettin no gas to the pistons but i have pressure coming from the part where my fuel rail hooks up but no gas inside the engine how to i check the fuel rail for fuel or if the injectors are working. im gonna double check all grounds and resand surface for maybe a better contact and gonna double check the wiring for the injectors. thanks for the reply if u could reply back it would be much appreciated im in a stomp and the performance shops around here are goofs lol.. i hope one of them read this thanks for the info
im using the p72 ecu for the gsr engine hooked up on the harness i figured the jumper did most of the work for me except for the cfk bypass and the intake air bypass.. im wondering becuz i already had a knock sensor and i jus cliped it in and didnt change where it runs i still checked the pins and the jumper goes from the obd1a d6 to d3 on the obd1. Althought the knocksensor wires should be red and yellow of such if im correct and it is plugged into the back of the block. im wondering if a problem, could occur if i used the air intake temperature thing that connects into the intake manifold and used it and rewired it for the one for the gsr ontop of the manifold maybe that needed a different clipping? even tho i was looking thru both models and it said the gsr had an iat that was ontop of the mani so i rewired it there. in all said im wondering where the lines for the head go. considering theres one steel tubing attached to another. The bottom one goes into coolant the top one is attached to the head with a rubber tubing connectin to the top and jus a steel end. is that for a vacuum or coolant maybe the head isnt gettin a vacuum and wont start it isnt hoked up becuz i wantewd to see what comes out of it a vacuum or antifreeze. maybe that could be my simple fix any info would be appreciated thank u all.. if that could be a problem what does it hook up too and if i should maybe take out the cannister out of the gsr and replace it in the civic thanks all any info would be thankful its my daily runner.been without the baby for three weeks already
95 eclipse full exhaust cat back, headers, 4 12s 10 000 watt amp customized box, wide body kit, 19" konig,32" flat screen, carbon fyber buckets,greedy turbo intake and intercooler. etc
