gsr in 90 integ
i am planing to put a gsr in my integ its obd0 but thats no problem. i also have a sir trans for it, but before i put it in i wanted to get some itr pistons, ctr cams, skunk2 intake man, skunk2 cam gears, vafc controller, act clutch, and a light flywheel. i have thinking on getting my pw0 ecu chiped so it can rev up to 8500 or more. but i wanted to know if i wanted to shoot(nos) the car, whats the highest amount of shots will i be able to handle safely. and will that setup be serious? :hmm: :shrug2:
50-60 shot is conservative and safe with good power.
and it's nitrous (not trying to be a dick) NOS is a brand.. :D
there is a lot to consider when running spray that stems to proper bottom end assembly to fuel management and other little factors that are used to consider when spraying a certain amount of n02.
Like I stated above a 50 shot would be the max that I would do on a motor that isn't getting extra fuel delivery from the injectors.
