Hey, just a quick question. I got a h22 jdm in my 97 EK. Recently I just change the spark plugs and wires and it started to sputter on me. I was wondering could it be the gap size. I have mine set at .044 right now. If thats the problem should I go smaller or bigger?
No it doesn't end with -11. Hm, I check all the wires and ground see if there is any loose wires/plugs but I didn't find any. My firing order is right. When I changed the plugs/wire it worked for like a day without sputtering but then it just started to sputter again.
Hm, I will change my gap size today and see what happens. If that don't work then I will check the injectors/fuel. The motor is pretty much brand new. I got it from Hmotor.
