H22 EK swap
droszyk
Ok, I plan on doing a H22 EK swap. I already know that I need mounts (obviously), axles, which I plan on getting from hasport.com and I am going to replace the timing belt, water pump, clutch, flywheel, spark plugs and wires, and clean out the exhaust ports. I know I can send in my wiring harnesses to rywire.com for the conversion, but I would like to do it myself to save some money if anyone knows how. I also know that I need to cut a hole for the cable shift linkage. Im not too knowledgeable on that either. If anyone could help with that I would be more than happy for any information. Any other inputs or advice on a H22 swap is welcome too. Thanks.
